Patriot performance dual spring kit
Old Feb 9, 2009 | 05:43 PM
GMCtrk's Avatar
Default Patriot performance dual spring kit
So.....I'm thinking here....the springs I have sitting here are the PAC 1218s good to .600 lift. My heads flow good up to .650. I would like to use the Pat G torque cam aka 224/228 .637/.639 110LSA (+0), this is on LSK lobes I believe.
Anyways, so I would need to step up to a spring that can handle this. Do I need to get the .650 kit or the xtreme .660 kit? Also, does anything special need to be done to my heads to accept the springs seats/seals that come with the kit?
Finally, what is this reddish oil that is one my valve stems (heads came that way)? I'm assuming your supposed to assemble the heads with the valve stems lubed up.
Thanks.
Old Feb 9, 2009 | 08:15 PM
silveradokidd_4518's Avatar
yes you will need new springs if those springs are only rated at .600 and your cam lift is higher than that
dual springs will be your new best friend
Old Feb 9, 2009 | 08:46 PM
Also check out the PRC spring kit from TSP. No head modifications are needed.
Old Feb 9, 2009 | 08:47 PM
GMCtrk's Avatar
the patriot kit seems to be cheaper.
Also when I bought the heads, they specifically asked me @ TSP if I was using beehives or dual springs....like it makes a difference in some aspect of machining the surface for the seats???
Old Feb 10, 2009 | 05:38 PM
black4.8's Avatar
patriot dual extremes are a great spring and are good to .660 lift. you need a good dual spring. patriots are by far the cheapest. i think i paid $270 for the extreme version. plus you get ti seats, retainers, locks, and valve seals. complete kit.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
black6spdz
Jul 16, 2015 01:32 AM
4B11T
Jul 13, 2015 03:48 PM
NuckenFuts
Jul 9, 2015 08:45 AM
07NBSChevy
20
Jul 8, 2015 07:27 PM
