Part numbers for crank and alt underdrive pullies? 05 4.8 silverado thanks
Old Mar 3, 2011 | 10:52 AM
Justinrst's Avatar
Default Part numbers for crank and alt underdrive pullies? 05 4.8 silverado thanks
Hey guys what underdrive pullies do you recommend?
Also where to get them and the part number thanks!
4.8 v8 05 silverado
Looking for a crank and alt pulley so i dont lose power just doing the crank by itself. thanks!
Old Mar 3, 2011 | 12:27 PM
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
Powerbond under drive pulley. Scoggin Dickey has them for $199.99 & includes what appears to be an ARP bolt & both belts. The ALT pulley is separate, about $30
Old Mar 3, 2011 | 02:33 PM
Amedee's Avatar
Who r what is scoggin dickey? Thats a good price
Old Mar 3, 2011 | 08:56 PM
andrew383's Avatar
traveling mod
I recommend the stock ones
Old Mar 3, 2011 | 10:59 PM
badz24s's Avatar
Talking
Srsly? Look to the right of your screen & you'll see a box that says SDPC. I got my UDP from them. I bought the ALT pulley from Summit. You can tell Scoggin Dickey that you want a specific part # for the belt. The belt part #s/lengths can be found on Thunder Racing.com's website. The A/C belt is a certain size, the serpentine belt length depends on whether you are running the ALT pulley or not. I think without the ALT pulley, I ran 14.2 volts, once I changed the ALT pulley, it went back up to 14.4 volts.
Old Mar 4, 2011 | 06:19 AM
dirt track racer 81's Avatar
Need a tool to press the new pulley on? Don't risk using the stock bolt to press it on and possibly ruining the threads of your crank.
Old Mar 4, 2011 | 04:59 PM
Justinrst's Avatar
Anyone have any photos of the install? Does it look stupid with the 2 belts?
Old Mar 4, 2011 | 08:38 PM
lowslung85's Avatar
Ur truck already has 2 belts. will look the same.
Old Mar 4, 2011 | 08:42 PM
Swerve7rpm2000's Avatar
i bought mine off summit, trick flow udp with alt for 200$ but it did not come with a belt
Three6GMC
Nov 5, 2015 10:02 PM
ZONES89RS
21
Sep 24, 2015 05:58 PM
Castro45
24
Jul 31, 2015 07:13 PM
6.Slow06
Jul 7, 2015 09:19 PM
Mzay
Jul 6, 2015 11:05 PM
