Parish8 question? ConRod Bolts...
Originally Posted by parish8
i have heard this and was concerned too but many people just slap them in and have good luck so that is what i did.
i probably have 5000HARD miles on these bolts. i didn't resize and they are the standard arp rod bolts. i did the torqe and loosen 3 times trick and that is it. when i was nitrous only i was shifting above 6800 but now with the turbo i am shifting at 6400max.
just bring this to the top since i found it useful
So....... I'm left unsure of things here. I ordered ARP rod bolts yesterday. Are they going to cause a problem? I'll be shifting around 64 to 6600, with about 10lbs of boost I'd imagine/guess. Do I need the ARP's or should I leave well enough alone? Opinions needed.
Banned
i have run only the pro rod bolt in all my 5.3 and in the 6.0s and a few other motor i have builded never had a problem.and the 5.3 seen 7400 rpms more than once and the 6.0 has seen 7k a few times
Originally Posted by L-EATER
The whole re-sizing thing applies to rods that use conventional rod bolts with a nut like a regular SBC. Simply removing a capscrew bolt like ours and replacing it with another doesn't distort the rod like pressing out and in the bolts in a SBC rod does.
Howards Cams actually sells aftermarket racing powdered metal cracked rods for small and BBC. They are very strong.
Well...... I know I feel better. I was concerned about the process to follow when I go to install the new ARP rod bolts. It sounds like I just remove the old bolts and install the new?
Thanks, Jim
Thanks, Jim
I know of atleast 3 people out at the local track running arp rod bolts with 700+ hp in LS1's so I would imagine that could be considered very strong for a stock part.
Who is this moregripatwork character? I know the obvious but wondering why you would need a diff screen name.
Who is this moregripatwork character? I know the obvious but wondering why you would need a diff screen name.Thread
TAPyvehc93
Sep 12, 2015 08:19 PM
