1.8 Roller Rockers, Worth It?
Old Jan 31, 2006 | 06:09 PM
phasemaster1's Avatar
Default 1.8 Roller Rockers, Worth It?
Please List Pros And Cons On 1.8 Rollers
Old Jan 31, 2006 | 06:13 PM
03lowriderss's Avatar
I wanna knwo too?
Old Jan 31, 2006 | 06:32 PM
FarmerBeau's Avatar
Sexy Party Mod
Will you be running a cam? All the roller tips will do is reduce friction and prolly free up a few horsees with it. Also it will increase the net lift of your cam. If you have the stock cam (191*/190* .457"/.466" 114lsa) It will inrease the lift because, as you may know, your stock rockers are 1.7. Do a little bit of fancy figuring in this formula
intake (.457") / 1.7 = .2688
Take that number and multiply it by 1.8 and there is the net lift for the 1.8 ratio. = .483"
Do the same for the exhaust lift.
.466"/1.7 = .2741(1.8) = .493"
That will give you hp but you prolly ought to just go and get a performance cam that has larger lift and longer duration.
Not worth it IMO. GET A CAM!!!!
Old Jan 31, 2006 | 06:35 PM
FarmerBeau's Avatar
Sexy Party Mod
Oh yea and if you plan to run a performance camshaft with those 1.8 rockers, make sure that you dont put it on a cam that will make your lift > .600" with stock heads.
Old Jan 31, 2006 | 07:18 PM
mattrem's Avatar
I had them, they caused some valvefloat at high rpm. If you get them get adjustables. You would be better off with getting a cam. Roller tip rockers have been known to cause problems with the valvetrain in the LSX type motors. I have seen it myself and have also heard it from people with the high dollar Jesels. Doesn't mean it will happen to you.
Old Jan 31, 2006 | 07:24 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Well i got a set of jesel shaft mounts with the adjustable pushrod cup on them I guess we will see if they cause valve float or not. Valve float can be form any number of issues that were changed with the higher ratio rocker arm but we wont get into that.
Point blank if you want performance get a perfromance cam
Old Jan 31, 2006 | 07:40 PM
litreddevil's Avatar
Banned
i have 1.85 comp and no problems yet the main reason i got them is cause i have soild lifters.
Old Jan 31, 2006 | 08:02 PM
99Silver6.0's Avatar
No, get a bigger cam.
Old Jan 31, 2006 | 08:23 PM
Nice, Friend Went Out And Bought Them Tried To Stop Him But To Late Oh Well
Gadgetized
Oct 22, 2015 09:06 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
redbird555
Sep 30, 2015 09:28 AM
tim wellington
Sep 29, 2015 10:17 PM
