Parish, Big Tex, XLR8, Spark retard limit??
Old Jan 25, 2004 | 09:20 PM
Black Blown 02's Avatar
Default Parish, Big Tex, XLR8, Spark retard limit??
I want an easy way to test how much timing I can run before I mess with the timing tables.
If I changed the spark retard limit tables to say +17 deg, would that take my timing up to 17? (12-16.5 now)
Would KR still pull timing? If not, would it still show up so I could let off?
I just want to do this so I can know what to shoot for when I start modifying the tables.
Old Jan 25, 2004 | 09:32 PM
BigTex's Avatar
Without looking at it, I think that number is the number of degrees that cam be pulled by spark retard. So if it is 8, then 8*s of timing can be pulled. I haave mine a 6*s. Most trucks have a higher number. I looked at a friends 98 Z28, and it had 4*s!
Old Jan 25, 2004 | 09:36 PM
This particular table has -10 pretty much across the board. So i assumed it meant timing can be pulled down to -10 degrees. Or 10 atdc????
BigTex's Avatar
OK, then put it up to 17.
Old Jan 25, 2004 | 10:07 PM
parish8's Avatar
single digit dreamer
just take the high octane table and add 2 to the entire thing and go for a log, you can work on the sections later.
with efilive you can add timing on the fly. a delta of 2deg, 4deg, 6deg, anytime you want, it is prety sweet. good for the dyno i bet
Old Jan 25, 2004 | 10:18 PM
Ok, I'll try that. I hate this, the high temp here has been below 32 degrees here for over a month. I want to start getting my timing down, but I'll probably just have to change it back when it warms up again.
Is more timing always better if theres no KR? I need to get one of the new g-techs to see if my changes are doing any good.
That EFI live sounds pretty sweet! I checked out my EASE, and in my bidirectional controls, the only really usefull thing I can do is lock the converter. Wish I could do timing.
Old Jan 25, 2004 | 10:25 PM
XLR8NSS's Avatar
Adkoonerstrator
The only time I saw the spark retard table come into play was on the shifts. When it was at -10 I would see -10 degrees on the shifts. When I changed it to 23 I would see 23 degrees on the shifts. It didn't seem to affect the knock retard at all.
Old Jan 25, 2004 | 10:29 PM
So did it effect timing at all other than the shifts? Were you running more than 23 degrees during the rest of your run?
Old Jan 25, 2004 | 10:34 PM
XLR8NSS's Avatar
Adkoonerstrator
Nope, it only seemed to affect the timing during shifts. I am only running 23 degrees of timing since anymore than that cause massive knock retard. I actually get knock retard at 23 degrees but, it's not very bad.
Old Jan 25, 2004 | 11:11 PM
BigTex's Avatar
Looks like you either need to upgrade that knocker, or find someone who can tune.
Notice the rpms, advance, knock and MAF:
