PAGING: Anyone with a non-6.0 4L80E swap
Old Mar 30, 2004 | 08:03 AM
  #21
L-EATER's Avatar
11 Second Truck Club
Originally Posted by BlownChevy
Please
Blown-The carquest p/n is 2-1153 and it says "supplied to carquest by neapco" on the box. Hope that helps.
Old Mar 30, 2004 | 08:09 AM
  #22
Scream's Avatar
MOOBIES Moderator
Did you have your d/s shortened? If so, how much?
Old Mar 30, 2004 | 12:56 PM
  #23
L-EATER's Avatar
the stock d/s worked just fine! the 60 and 80 are almost the same exact overall length.
Old Mar 30, 2004 | 01:45 PM
  #24
bmbutler's Avatar
Good to hear.
If my stall gets in by this weekend. I should have the 4L80 in by Sunday!
I think I have everything I need.
Old Mar 30, 2004 | 01:49 PM
  #25
Scream's Avatar
MOOBIES Moderator
Do you need to get all of the tranny lines? It looks like all 80's came from the factory with a cooler. I don't have one, so will I need to get one, or can I mount an aftermarket cooler in front where the stock one would be?
Old Mar 30, 2004 | 02:08 PM
  #26
bmbutler's Avatar
I would recommend you get one. It'll be easy in my situation since the motor's out anyways + I think its worth the extra insurance IMO.I am not even using the stock trans cooler, but I will be pmounting the cooler in front of the radiator.
I got one of the biggest ones B&M has to offer from Allen. I'm also not purchasing new lines...I'm gonna bend my own.
Old Mar 30, 2004 | 03:18 PM
  #27
My stock driveshaft fit,I used a TH400 yoke with a special u-joint to adapt the different size ends.
Old May 5, 2004 | 09:31 AM
  #28
Scream's Avatar
MOOBIES Moderator
Guys, another question--what is the difference between the 2wd and 4wd cases for hte 4L80E? Would it be possible to convert a 4wd tranny to work in a 2wd truck? What parts and how expensive would they be?
Old May 5, 2004 | 04:22 PM
  #29
quicksilverado's Avatar
Starter will work, I just asked Parish and his bolted right up. You will need the flywheel though.
Where do you get a flywheel?
Old May 5, 2004 | 05:32 PM
  #30
MacADaYear's Avatar
Try 750 for that driveshaft ... Dennys wont make the N20 driveshaft in our lenght. You need a HD aluminum....
