Pacesetters Are Here!
Old Sep 25, 2006 | 02:44 PM
  #31
99/5.3w/hips's Avatar
Originally Posted by trever1t
NO.
It is illegal in this fair state to run long tubes (unlees you have a pre-'78?). Moving the cat from stock location is also illegal. $1000 per cat and referee for life.
I wish for LT's. Those look real nice
I think its 76 Bill. Im pretty sure its 30 years before whatever year it currently is. I remember my buddy was waiting for it to be 2004 so bad in 2003 because it meant his 74 chevy was smog exempt and he could stick a 502 in it.
oh btw CaliChevyV8 you might want to keep a tube of lube in your truck from now on. If a cop pulls you over and finds out you have an ORY instead of 2 cats then your out 2 grand right there...but if you can get away with it i would keep the stock setup and just swap them when it comes smog time. But you still run the chance of getting caught.
Old Sep 25, 2006 | 08:02 PM
  #32
jakebdb56's Avatar
Originally Posted by BLACKHD01
On my set up I won't be using a ORY, the 2500HD has seperate 3 inch pipe from each side, so no slip fit for me. I guess I could just butt the three inch pipe to the collector and then use a clamp and see how it will work. If that doesn't work then welding on a 3 bolt flage is my next option I guess.
goto a muffler shop and get them to take a piece of 3" tubing and expand one end to 3" pipe. then you'll have a good slip fit. the pacesetters fit damn good with the 3" pipe over it. the ORY is just 3" tubing with expanded ends... just slip fit over the collector and put the stainless clamp over the fitting
btw tubing and pipe are completely different, tubing is measured by outside diameter and pipe is inside diameter and doesn't always have a uniform wall thickness even though it's teh same schedule, tubing is always really accurate depending on what specs.
Old Sep 26, 2006 | 08:34 AM
  #33
BLACKHD01's Avatar
Thanks for the info. That is probably what I will do.
blown02408
Feb 24, 2016 04:50 AM
Cowboy Tom
11
Sep 16, 2015 09:35 AM
bisqikss
Sep 8, 2015 03:35 AM
USMCvet0311
Sep 4, 2015 09:43 PM
Layn22s
Aug 31, 2015 03:43 PM
