pacesetter lt
Old Feb 13, 2007 | 05:38 PM
slownlow4.8's Avatar
Default pacesetter lt
my headers came in to day."finally" just wanted to know what kind of gasket you all are using, OEM or something else
Old Feb 13, 2007 | 05:41 PM
My pacesetters came with white gaskets and wiring to lenghthen your o2 wires.I think the stocker will work fine.
Old Feb 13, 2007 | 05:47 PM
dirt track racer 81's Avatar
mine and dozerdans came with copper gaskets
Old Feb 15, 2007 | 08:23 PM
are they supposed to come with necessary gaskets and fasteners
Old Feb 15, 2007 | 09:14 PM
Guess it depends on who you bought them from, I think mine came from speed engineering. with gaskets, wiring, but no bolts.
Old Feb 15, 2007 | 09:26 PM
i bought them from speed engineering so should i have gaskets, wiring too
Old Feb 15, 2007 | 09:47 PM
KevinF56's Avatar
i had copper gaskets with mine which i used. but i didnt have an egr block off plate. go figure. guess it just depends on what you get with them. you can reuse your stock ones, but i'd suggest maybe going and buying stock ones. cant hurt to get some clean ones in there.
Old Feb 15, 2007 | 10:01 PM
yeah i'll most likely buy new stock ones
Old Feb 16, 2007 | 06:48 PM
xlcooplx's Avatar
im going to reuse the stock ones when i install mine as they will work perfectly fine. if you've already reused them once though, i would consider buying new ones.
Old Feb 16, 2007 | 06:55 PM
blake2kz71's Avatar
i used oem on mine and no problems here. i also used dynatech 2 bolt stainless clamps instead of the ones that came with them.
