Pacesetter header install
Well i started my headers install today. I got everthing off, and put the passenger header on. My question is do you install the driver side header from the bottom or top? I was hoping to install them withouth unbolting the steering, but it was getting in the way from both directions. Also, if i have to, where do you un-bolt the steering from?
thanks
thanks
Install from the top. Pull the bolt out of the steering shaft. It's mid ways down where to two shafts connect to one. simply pull the upper half of the shaft out. be careful when you install the bolt back. it rubbed the coating off of my pacesetters.
I did mine from the bottom. Just jack it up so you can get the headers in a nice vertical angle and slide em right up. Just take out that 1 bolt on the steering and its out of the way. Get it up in there, bolt it up, hook the steering back up with that 1 bolt and there you have it.
