opinions: STS vs RADIX
Old Sep 11, 2004 | 03:48 PM
  #181
moregrip's Avatar
what a rush!
Originally Posted by XLR8NSS
I'm not sure what post he was referring the gas law to but, it's just a law that relates how pressure, volume, and temperature of an ideal gas relate to each other. It just shows how if you change one or more of the variables how it effects the others.
thats what I'm saying, how am I supposed to apply this formula and what value should I be concentrating on, pressure, volume, or temp as the cause to the reference effect?
Old Sep 11, 2004 | 03:53 PM
  #182
XLR8NSS's Avatar
Adkoonerstrator
Talking
Depends on what you're trying to figure out. Maybe Ryan will chime back in and let us know what post he was referring this formula to, then we can do some work with it.
Old Sep 11, 2004 | 03:55 PM
  #183
moregrip's Avatar
what a rush!
sounds good to me, let's nuke this out
Old Sep 11, 2004 | 05:03 PM
  #184
Arigom's Avatar
I think Ryan was just trying to say that if the SC gets hotter it will build pressure faster according to the thermodynamic formula. As temps go up so does pressure. However, increased pressure is not technically why you get more HP - it's the added mass of air. Although, they ARE a function of each other.
Not to argue with proven thermodynamic laws but that doesn't make sense to me. I thought that if you could cool down the charged air (I know you get more HP for cooler air, but) - you would also run a little higher boost. For instance, upgrade your FMIC and boost levels usually raise or how you get more boost in the winter. Is this not right. How can they both be true.
unless he means you raise the pressure faster being hot - agreed
but you make more hp being cold - I think
but aren't they a function of each other....I'm getting a headache with all these assumptions
Someone please clarify
Ryan did give props to the Radix - although he clarified his stance on the "leaking" past the blades. Aren't we in agreement that there is a certain level of inefficiency's with each system - and that all are well made for the technology of today. Although reliability of the turbo's has come up. Moregrip raised an interesting point....how long do the Garrett turbos last - understand that they will be running 500 degrees cooler than other applications so we could assume, (there I go again) (yes, I know the acronym) a longer life span.
Old Sep 11, 2004 | 05:16 PM
  #185
moregrip's Avatar
what a rush!
The Twin Screw argument should be; and I may be wrong, how does the thermodynamic law help the twin scew SC overcome its greatest negative, "any Off Boost Condition", so that it equals or out performs the Radix/modified roots blower, in building off idle boost quicker.
Again, my position is, there is no way the twin screw SC can build off idle boost faster than a Radix due to the fact that it must first overcome its greatest negative to then build boost, however, once it starts to build boost it is more efficient at it. The radix, however, is a cheetah waiting to explode into a full sprint, so to speak, it is 1 step away from productive boost, while the twin screw is 2 steps. Now, can the twin screw really boost faster off idle? I say no.
Old Sep 11, 2004 | 05:28 PM
  #186
Arigom's Avatar
Sounds good - I say no as well - just still not quite sure why.
Old Sep 12, 2004 | 11:23 AM
  #187
moregrip's Avatar
what a rush!
here's a pick of some twin screw rotors, nice!
http://www.harrop.com.au/root_folder...lm_rotors.html
Old Sep 12, 2004 | 09:14 PM
  #188
moregrip's Avatar
what a rush!
Are we done here?
I'm sorta waiting to hear from Ryan, Naked AV, Flyer, and BlownChevy to get some final collaborative thoughts on this?
I'm calling you guys out!
Old Sep 12, 2004 | 09:18 PM
  #189
Haven't you already quoted every website out there?
Old Sep 12, 2004 | 09:19 PM
  #190
moregrip's Avatar
what a rush!
no more plagerism here bro! I left your name off the list though, so what are your final thoughts?
