Okay got my 130A alt in...
Old Sep 9, 2003 | 04:22 PM
Hit Man X's Avatar
Default Okay got my 130A alt in...
Well the stock belt won't work, trust me I tired not shell out $22 for the new one but had to. I got a Goodyear belt from "The Zone" LOL.
Anyway the install is pretty straight foreward, pull old wuss 105A by taking out 2 bolts, disconnect battery wire, and voltage regulator. Use a hammer to persuade the two brass looking rivits that where the alt goes inplace for a easier drop in.
So with my stock crank pulley and stock alt pulley I now have over 14V at idle with the A/C on 5, fans blasting, and the headlights on!
Moral is... good mod for ~$100 all said and done.
Old Sep 9, 2003 | 04:33 PM
Tokez420's Avatar
Default Re: Okay got my 130A alt in...
did u get it off the guy on ebay??
Old Sep 9, 2003 | 04:36 PM
Hit Man X's Avatar
That is correct. I just called them directly from their number on the auction listing. They ship UPS (the sloooooooooow shippers) so it took me like 10 days to get it!
Old Sep 9, 2003 | 04:45 PM
bigguy75inches's Avatar
i too just installed the 130 alt. from the ebay guy. it was a breeze to install but the belt was too short. BUT,,, since i have a whipple supercharger, it has an adjustable pully to manually tighten or loosen the belt. i was just able to move the pully over some to give me some more slack. piece of cake.
Old Sep 9, 2003 | 04:50 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Pics?
Is there a part number or something so I know which exact one to look for?
Thanks
Old Sep 9, 2003 | 04:56 PM
Hit Man X's Avatar
http://cgi.ebay.com/ws/eBayISAPI.dll...category=33573
There ya go.
Old Sep 9, 2003 | 06:17 PM
rgvsierra's Avatar
wonder how it will work with the asp crank pulley, e-fans, small system, and the lights on at night?
anyone try this amp with those accessories running.
Old Sep 9, 2003 | 08:11 PM
Hit Man X's Avatar
Ask 1BADHD about that
Old Sep 9, 2003 | 08:25 PM
1BADHD's Avatar
You will need more than 130. I have almost the same set up. I had to get a 200 amp. Even then I had to have my idle raised abuot 125 rpms to make the alt produce the right voltage at idle. And that is with a overdrive alt. pulley!
Old Sep 9, 2003 | 08:48 PM
rgvsierra's Avatar
so to make it right, i would need to add a overdrive alt pulley, plus a 200 alternator.. wow.. i guess i can find power other than e-fans for now..
when this stock alt goes, i will try that 130 amp with the currect setup i have to see if it helps out with my voltage at idle trouble..
