Oil usage...
Old Aug 25, 2005 | 07:51 AM
BLACKHD01's Avatar
Mine uses about 1qt every 1000-1200 miles, the dealership is doing a oil consumption test right now, so we will see what happens.
Old Aug 25, 2005 | 08:14 AM
white1's Avatar
Mine didnt use any till I changed my PCV valve. I hape it doesnt start using more with the heads/cam swap
Old Aug 25, 2005 | 07:54 PM
white lightning SS's Avatar
for 8.1 oil consumption there is a lifter valley cover gasket update(tsb)
for 5.3 ther is a fixed orfice update (tsb0 which did not do sh*t on my old 02
5.3) what fixed it was an ls6 lifter valley cover w/ internal baffle. bolts right up and all you have to do is run the hose down to it. this part i beleive is around 60 bucks.
Old Aug 25, 2005 | 08:11 PM
litreddevil's Avatar
Banned
Originally Posted by chevymec
We ran into this at work a while back with an 8.1 using 2 qts between oil changes. I called GM and they said that the more gas used, the more oil used and the customer used alot of gas from week to week. I havent changed anything but I still drive about 350-400 miles a week.
hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
Old Aug 25, 2005 | 08:20 PM
02sierraz71_5.3's Avatar
is it possible to just put a breather on the valve cover and plug the intake hose
Old Aug 25, 2005 | 08:27 PM
chevymec's Avatar
Dont know how ive been missing all those TSB !!
Old Aug 25, 2005 | 08:32 PM
Banned
jjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj jjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj jjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj jjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj jjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj jjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj jjjjjjjjjjj
Old Aug 25, 2005 | 08:52 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by litreddevil
I WANT TO GET ONE OF THEM CANISTERS THAT GUYS HAVE BEEN PUTTING ON THE PCV SIDE.
I drain a few teaspoons of oil from my catch can every 1 to 2k...
Old Aug 25, 2005 | 09:16 PM
THIS IS ON THE OTHER SIDE THE SAME SIDE AS PCV. BUT ALL I DID WAS PLUG THE HOSE THAT GOES TO THE TB,ON THE TB SIDE AND JUST LEFT THE HOSE OPEN.
thats what Im talking about Ive always wondered why ventilate the crank case to the intake, what is the reasoning. Couldnt I just put a filtered breather on the crank case and plug up the hose going to the intake. Do you think there would be anything harmful in that?
Old Aug 25, 2005 | 09:17 PM
chevymec's Avatar
Is the company that makes the catch cans making them again?? I saw the site a WHILE back and they were all out of stock.
