oil pressure sender socket size?
Only the special socket will work with the coolant block off installed on the back of the head. If you remove it (10 mm bolt) it would be easier. I have the actual oil pressure sender socket...It actually has "Do not use with engine running" stamped into it. Damn you know someone did that and sued or something. PS there are 2 oil sender socket sizes... 1 1/16 and 1 3/16
Dave
Dave
Stainless Works
13
Nov 5, 2015 03:31 PM
superchomper2003
Aug 26, 2015 09:39 AM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
