oil pressure sender socket size?
Old Oct 1, 2006 | 05:15 PM
adam1803's Avatar
Default oil pressure sender socket size?
Does anyone know off hand? i need to go buy one tonight. Thanks
Old Oct 1, 2006 | 06:02 PM
Bowtie70SS's Avatar
I believe it is 1 1/16 I'm pretty sure anyway. I had to replace mine the other day as my scan gauge said I had 121psi of oil pressure.
Dave
Old Oct 1, 2006 | 06:04 PM
adam1803's Avatar
cool, thanks
Old Oct 1, 2006 | 07:08 PM
99Silver6.0's Avatar
Be nice to that thing. They break so easily!!!
Old Oct 1, 2006 | 09:13 PM
Bowtie70SS's Avatar
You should try reaching it behind a radix with 3 extensions and a swivel...oh the pain
Dave
Old Oct 1, 2006 | 09:41 PM
2004SSS's Avatar
they actually have a speacial socket for them but i know a regular socket can do the trick.
Old Oct 1, 2006 | 10:10 PM
Bowtie70SS's Avatar
Only the special socket will work with the coolant block off installed on the back of the head. If you remove it (10 mm bolt) it would be easier. I have the actual oil pressure sender socket...It actually has "Do not use with engine running" stamped into it. Damn you know someone did that and sued or something. PS there are 2 oil sender socket sizes... 1 1/16 and 1 3/16
Dave
Stainless Works
13
Nov 5, 2015 03:31 PM
superchomper2003
Aug 26, 2015 09:39 AM
maxspeed05V
Aug 12, 2015 06:29 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
jrplz
Jul 9, 2015 12:07 AM
