Oil pressure guage droping over last month!
Old 01-27-2019, 10:51 PM
Danlee126's Avatar
Default Oil pressure guage droping over last month!
2000 5.3L Gen III with 210K miles cam boltons. Stock oil pump
Oil pressure used to be 40psi idle 55psi cruise on highway 70psi wot for its last 100K+ life. Now it is 35psi max no matter what and gets down to 25 psi on idle.
Curious if it is the oil pump or oil sensor or motor in the oil gauge is. How to test?
Thanks
Old 01-27-2019, 11:19 PM
FFDP's Avatar
Pull the stock sensor and hook up a manual oil pressure gauge to that port.
If that reads what the dash reads, then you probably have a real problem like the oil pump itself or worse.
Old 01-27-2019, 11:27 PM
Danlee126's Avatar
Thanks for the reply!
Where is it located on gen III? l'm googling at the moment.
Old 01-27-2019, 11:30 PM
FFDP's Avatar
Behind the intake manifold by the firewall on the drivers side.
Old 01-28-2019, 06:47 AM
13 Second Truck Club
trxmxzx's Avatar
When I bought my 99 it had some cheap oil that broke down within 1000 miles and showed same thing - changed with quality oil it was back to normal
my buddy in his 2000 was a pick up seal failed
Old 01-28-2019, 07:46 AM
arthursc2's Avatar
Received 1,435 Likes on 1,062 Posts
I am putting my money on the pick-up o-ring
I think Ive gone through 3 of them so far. 2 on the Tahoe (OE and then tore one doing the adjustable timing set) and on a friends Yukon we had to do an o ring. Kinda sucks to do in the truck, but with 8mm ratcheting wrench and a dremel, its possible
Old 01-30-2019, 03:25 PM
Replace the sensor first just cause it’s the easiest fix. I had a similar issue an that fixed the gauge reading.
Old 01-30-2019, 11:26 PM
100% Redneck
RedXray's Avatar
Received 1,331 Likes on 793 Posts
All the above...
sending an oil sample to Blackstone for analysis would detect abnormal amounts of bearing material and other metals floating around.
texasbullseye89
09-08-2010 05:21 AM
PappyDan
10-15-2008 10:43 PM
Formulized94
05-07-2007 09:12 AM
JimS
04-24-2006 11:57 AM
ThunderZ28
04-06-2005 08:02 PM
Quick Reply: Oil pressure guage droping over last month!
