Oil and Coolant now Occupying Same Space
Old Mar 8, 2022 | 03:36 PM
  #31
zz454Chevelle67's Avatar
Found a gen 4 6.0 with 80K on it, DOD has to go but I`m seriouly considering this one, it has LS3 heads but I would replace those for cathedral port heads I think. Rounded up an engine stand guess I`m gunna buy a hoist, gave all that crap away decades ago to make room.
Old Mar 8, 2022 | 03:49 PM
  #32
wretched73's Avatar
If you get it and want to sell the heads, I may be interested
Old Mar 8, 2022 | 06:30 PM
  #33
smokinlmm's Avatar
Second in line for heads if the deal works out.
Old Mar 8, 2022 | 10:27 PM
  #34
theunderlord's Avatar
random question, but were your rings gapped for boost?
Old Mar 9, 2022 | 12:41 PM
  #35
No the rings where not gapped for boost they where stock LM7 pistons and rings. Went 15 years with a Magnuson Radix no problem at 7 lbs but only 2 years with turbo at 12 lbs then 4 months on 14 lbs. So that brings up a good question, how critical is it to gap rings for boost in a daily driver that only sees max boost accasionnaly.
Old Mar 9, 2022 | 12:46 PM
  #36
Ouch. Yeah, what happened here is your piston ring got *real* warm from all that increased cylinder pressure, butted the ends together, folded over and wrecked your ****. Gapping your rings for boost is absolutely 100% a critical step in boosted engine survival. .026 for the top, .028 for the bottom give or take.
Old Mar 9, 2022 | 01:19 PM
  #37
Well dam feel like a dummy now, lesson learned tho.
Old Mar 9, 2022 | 01:29 PM
  #38
arthursc2's Avatar
Its ok, she went a long time ungapped. Opening it up helps significantly tho
Old Mar 9, 2022 | 01:32 PM
  #39
It's all good man, lesson learned. Assuming your engine block can be cleaned up, have the machine shop try and finish the bores to a common size that is supported by the aftermarket. Summit makes an entire rotating assembly for the LS that is reasonably priced. Or just go pistons and rods assuming your crank survived unscathed. The stock crank is good for ~1,000HP give or take.
Or find another LS from a JY and pull it all apart for some super fun ring filling.
Old Mar 9, 2022 | 08:54 PM
  #40
RDF1's Avatar
DuNnO
5 Year Member
I never gapped the rings In my 6.0. It lasted over 300k miles with a turbo on it. And towed with it every weekend.
water/methanol injection prolly kept it alive tho cause it was staying in boost for a long time pulling hills with a heavy trailer
