Oil and Coolant now Occupying Same Space
#51
Ouch. Yeah, what happened here is your piston ring got *real* warm from all that increased cylinder pressure, butted the ends together, folded over and wrecked your ****.
Gapping your rings for boost is absolutely 100% a critical step in boosted engine survival. .026 for the top, .028 for the bottom give or take.
Gapping your rings for boost is absolutely 100% a critical step in boosted engine survival. .026 for the top, .028 for the bottom give or take.if OP was curious, he could check the rings on some of the pistons that survived.
#52
I thought about that but ended up just tossing them in the trash, waiting on machine shop now to bore block and valve job on heads replace bent reluctor wheel. Going with forged Mahle pistons and rods. Going a lot slower than I had hoped partly because I don`t have much time to work on it.
#58
Finally have a little progress to report, the machine shop called this morning and said everything is ready to pick up. $3200 dollars for block hone, Mahle pistons and rings valve job and porting 706 heads, balancing and new timing gear set. I havent had an engine at machine shop in decades so not sure if thats good bad or just ugly price. So tired of truck being dead in the driveway I'm just glad to make progress.
#59
I just had my windshield replaced and it was double what I paid in 2015... When I was talking with the owner. His cost on everything has gone up 38% alone just this year.
#60
Good to hear progress, mine is taking forever to finish as well. Parts and good people are hard to find now so it takes longer. I'm a marine electrician and my parts costs have almost doubled this year already...
