Oil consumption
The check oil level light came om in my 2000 z71,its got 89000 on the clock.When I checked it it was barely showing on the dipstick.The truck has never used oil,changed every 3000 miles,what the f@$%,any opinions?
Also check and see how much oil is being sucked through the PCV valve...if the hose to the PCV is full of oil, you could try swapping in the fixed orifice style PCV or getting a catch can...
Bad valve seals can cause SEVERE oil usage.....I've seen a motor with bad valve seals use a quart of oil every 200 miles, it's kind of suprising just how much oil can find it's way down the valve stem when the seals go bad
Pulled the throttle body off and didnt see any excessive oil inside the intake,also pulled the pvc valve out and no oil in the tube to the intake,The truck doesnt smoke at all. 89,000 and rings shot? btw The truck is bone stock I have had it over 2 years and never had to turn a wrench on it.
lukn4trbl355
Oct 21, 2015 11:19 PM
lxcoupe
Sep 25, 2015 12:36 PM
69z-28
Sep 21, 2015 07:31 AM
