Which oil is the best of the best?
#21
Mobil 1 and a PF59
Every 3k or 3 months - whatever comes first.
I have used Mobil 1 in everything I have owned
for years and never have had a oil related failure.
Additionally - everything I changed to the Mobil 1 from the OE oil
I always had an increase in oil pressure - always
#22
Has anyone honestly ever had oil related failure in anything? When i was a boat mechanic we changed oil every 100 hours. Thats 100 hours of 5000-5500rpms on average. Thats alot of abuse, and ive never seen failure due to oil. The old Cris Craft fords were known for spitting rings and flattening cam lobes. But thats fords for ya.
#23
Originally Posted by sloblaze
Your talking about a 2 stage oil filter....I have been trying to find them to fit 99-02 Chevy trucks with no luck, can you give me a name or a web address? Most big rigs use 2 stae oil filters, cause the way they make it out to be is that with the good syn(royal purple, redline, amsoil) they never break down just get dirty and by chenging the filter can run the oil for 10,000 miles...not that i would ever do that but probably for at least 6,000 before an oil change...Thanks.
amsoil have the 2 stage filtration for our trucks sorry about the bang could't resist
#24
I've been using Neo Synthetic race oil in 0w-5 since my car was new 5 years ago. I don't use any type of spin-on cartridge filter but a racing unit that flows 45gpm and filters down to 8 microns with no by-pass. It's a depth filtration type filter used in racing. Because of the way it filters it's not necessary to change the element out every oil change, but every other oil change. You do have to drain the oil from the filter housing when you change the oil. Neo Synthetic has other oils in different viscocities. The 0w-5 race oil will cost you about $10qt or $35 per gallon. You could go with their race grade oils and really stretch out the oil drain intervals.
www.bakerprecision.com
www.neosyntheticoil.com
#25
so was that Chris Craft an old "Woody"?
i love those inboards
#26
I too run 10 30 valvoline
when I worked at a machine shop it pretty much sold me on valvoline
because of the looks of the engines and how clean they were
I would also not have a problem running mobile 1 or castrol
some of the dirtiest engines, heads, etc ran havoline or quaker state
lukn4trbl355
Oct 21, 2015 11:19 PM
lxcoupe
Sep 25, 2015 12:36 PM
69z-28
Sep 21, 2015 07:31 AM
