Official NBS V6 to GENIII V8 swap Guide
Old 04-11-2018, 01:58 PM
  #231
100% Redneck
RedXray's Avatar
Received 1,331 Likes on 793 Posts
Originally Posted by RedXray
So the OEM 2wd V6 right (pass) side mount will work with the V8 2wd swap? Can someone confirm the passenger side indeed works before I drop $50 for that new mount
Just got back from the salvage yard... couldn't find the V8 motor mount brackets so I'm going to have to buy new. Will the 2wd V6 passenger side work? Or do I need both sides?
These are the last part(s) I need for the swap... any input would be appreciated
Old 04-11-2018, 02:33 PM
  #232
The_W's Avatar
I found a set of mounts from a v8 junkyard truck, back when i swapped mine from v6 to v8. Instead of using both brackets from v6.
Old 04-11-2018, 03:52 PM
  #233
100% Redneck
RedXray's Avatar
Found one 2wd that didn't have an engine. Removed both mounts with a big smile on my face. Then I thought... maybe I better check the VIN. Sure enough it had a W (v6) FML lol.
Somebody tell me the 2wd V6 passenger side works and save me $50
Old 04-17-2018, 12:05 PM
  #234
prican_2000's Avatar
Hey Buddy - now its "MY" time to help you out!!!
Yes the 2WD V6 Passenger side motor mount WILL WORK. I will attempt to attach a pic of the old ones I removed from the 2WD truck and the new one I bought. the only reason why I had to buy a new one was because I broke the bolts inside the threads and did not want to have to drill them out. see for yourself. Good Luck!
Old 04-24-2018, 08:46 AM
  #235
Registered User
Sebastianrocha's Avatar
Default Help
Im putting a 2004 6.0 in my 1999 single cab but i have the harness from the 6.0 would everything plug right in and work ik i have ro change gas pedal but would the harness work with all ly gauges or do i have to send my harness to ger made up for the 99 silverado single cab
Old 04-24-2018, 01:55 PM
  #236
Custm2500's Rude Friend
1FastBrick's Avatar
No, a 03-07 classic harness will not bolt in and work with a 99-02 chassis. There are some differences in the wiring under the fuse box.
Old 04-25-2018, 01:51 AM
  #237
Nwfjarhead's Avatar
I’m looking for the harness you have for my 06.if you are interested in selling it pm me . Thanks.
Old 04-25-2018, 10:18 AM
  #238
100% Redneck
RedXray's Avatar
Hey prican thanks for the conformation that the pass V6 mount will work!
BUT I was to STUPID by NOT checking for replies to my question...
Look what the FedEx guy brought this morning
Old 04-25-2018, 01:18 PM
  #239
Registered User
Do i get a new fuse box or i just send my harness get made for my 99 sipberado
Old 04-25-2018, 04:09 PM
  #240
1FastBrick's Avatar
Cheaper to buy a 99-02 V8 harness
Quick Reply: Official NBS V6 to GENIII V8 swap Guide
