Official NBS V6 to GENIII V8 swap Guide
Old 06-06-2018, 02:05 PM
  #251
100% Redneck
RedXray's Avatar
Received 1,331 Likes on 793 Posts
Originally Posted by _zebra
granted it's been 9yrs, but i think i carefully popped them out of the bracket to separate them enough because i do remember using one of those little tubing cutter wheels that you tighten & roll around it until it cuts through.
Thanks... I'll have to take a closer look, at first inspection I couldn't see anyway to separate. I did notice the bracket seemed to be made from two pieces.
Old 08-24-2018, 03:58 PM
  #252
Registered User
Evan Duke's Avatar
Default Wiring harness under fuse box
Im am swapping an 09 LY5 into my wifes 09 4.3 silverado. Everything is going good except this big connector under the fuse box where the engine harness plugs into the body harness.....why is nobody talking about this and what did i do wrong?
Old 08-24-2018, 04:08 PM
  #253
Registered User
Evan Duke's Avatar
Default Pictures
This is the connector
Body side
5.3 engine harness side
Old 08-25-2018, 06:34 AM
  #254
Chado2448's Avatar
Because this thread is about nbs trucks not nnbs.
Old 08-25-2018, 07:21 AM
  #255
Registered User
Evan Duke's Avatar
Ohhhhhhh. Had no idea. Well any help would still be greatly appreciated. I dont see any way around replacing the body harness with one from a 5.3 truck
Old 08-26-2018, 04:43 PM
  #256
makes children cry
_zebra's Avatar
yep, this is for the GMT800 body style.
and sorry i can't help, but i can bump the thread.
Old 10-02-2018, 02:04 PM
  #257
AMS13's Avatar
Question for you guys. I have read through the entire thread, and searched but I can find the answer. I have a 04 Silverado with the 4.3. I understand I would need a 03-07 classic 5.3 or 6.0 in order for the swap to work and be as easy as possible, but what about 04 5.3 out of a Express van? The motor is drive by cable, and I know the 03-07 classics are drive by wire.. would I have any trouble using this motor? It is a complete drop out so I would get the pcm and other goodies.
DieselDave359 (03-18-2020)
Old 10-02-2018, 06:09 PM
  #258
FFDP's Avatar
It should work.
Maybe some minor things here and there but if it's a complete drop out with harness and computer that makes things easier.
Old 11-22-2018, 02:38 AM
  #259
Little_Mata's Avatar
Hello I’m pretty new to this thread but I have some questions about a swap I’m trying to do. So my truck is a 2002 v6 Silverado. The engine that Im trying to drop into it is a 5.3 from a 2004 Tahoe. I have the wiring harness, pcm, and fuse block from the Tahoe and my concerns are this: is the harness and pcm going to be compatible for my truck and will it be an easy “plug and play” swap for me? Or will I have to get a harness and pcm from a 99-02 Silverado?
Old 11-22-2018, 03:18 PM
  #260
arthursc2's Avatar
Received 1,435 Likes on 1,062 Posts
Harness, PCM, DBC throttle body from 99-02 will be easiest
Quick Reply: Official NBS V6 to GENIII V8 swap Guide
