o2 Sensores HELP!!!
Old Feb 26, 2005 | 09:43 PM
SD-Silverado's Avatar
Default o2 Sensores HELP!!!
I'm installing my dynatech system.
I was following the intructions step by step.
Came to removing the stock o2 sensors, 1st one came off fine, a little tight, took some effort.
Yet the other 3 are NOT coming off. At first all 3 broke lose, a few turns, seemed be becoming easier the stopped.
I don't have a o2 socket so i was just using a open faced wrench. I'm pulling/pushing with all my might and nowhere. I took the Y pipe off with the sensors still attached, figued I could get a better go at it rather than on my back. Still no go.
What is the trick to these? I even tried clamping on a vice grip and whacking it a few times with a sledge.
Do they have to be warm when you take them off? I'm about to take a torch to it, heat them up and see if they come off. If that doesn't work, I'm just going to buy 3 new sensors....
There HAS to be a way to get these off...
Old Feb 26, 2005 | 09:57 PM
Tomorrow I'm gonna go down and pick up a o2 sensor socket, then take my breaker bar to it.
Old Feb 26, 2005 | 10:27 PM
goshawk23's Avatar
Truck addict
i would just heat them up a bit before taking them off. i have never removed mine but metal to metal, heat expand, cool shrink, over and over again.....i would try heating the pipes just a tad to see what that would do.
Old Feb 27, 2005 | 02:41 PM
Well, breaker bar and socket didnt do crap....I tried heat...nogo. This is ridiculous....
Old Feb 27, 2005 | 03:03 PM
mattrem's Avatar
I had the same problem with one of mine, it tore the threads right off it. I ended up buying a new one from GM, 125 bucks later.
Old Feb 27, 2005 | 03:11 PM
Just make sure you use anti seize compound on the threads when you install them, so next time they will come out fairly easy.
Old Feb 27, 2005 | 04:08 PM
nightmarechevy's Avatar
I just sprayed some WD-40 on mine and they came out pretty easily, just used a wrench to take them off and had no problems. I would think that they would come out fairly easily after some heat and WD-40. Good luck with it, hopefully you can get them out soon.
Old Feb 27, 2005 | 07:10 PM
I tried 3 in 1 oil and WD 40, no go. I then applied a LOT of heat to them. They finally came out yet with the threads stripped. =(
Looks like I need to buy 3 BOSCH 15824 o2 sensors. I picked one up at autozone, 99$. NAPA wanted 198$ Crazy.
Old Feb 27, 2005 | 07:35 PM
P.O.R.N.'s Avatar
Wish I wold have read this sooner i have 2 o2 sensers just taking up space in my tool box. would have sold them to you. But I gess thats not going to help you now.
Old Mar 1, 2005 | 02:01 PM
Oh well. Thanks for the thought! =D All sensors bought now, headers are in and sound badass!
