O2 sensor hits floor pan with long tube install! HELP!
Old Mar 31, 2013 | 11:36 AM
Slammed silverado's Avatar
Default O2 sensor hits floor pan with long tube install! HELP!
Has anyone ran into this?
Old Mar 31, 2013 | 12:19 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Is your transmission installed??
Old Mar 31, 2013 | 12:24 PM
Yea it's installed
Old Mar 31, 2013 | 12:28 PM
Then I'd probably remove that heat shield and cut off that stud. Should be okay then. You're not running cats so the shield isn't needed.
What brand headers are those?
Old Mar 31, 2013 | 12:38 PM
Texas speed and its not hitting the stud it is hitting the floor pan
Old Mar 31, 2013 | 10:42 PM
Hawk1266's Avatar
I have the same problem. Took the heat shield off and there's a part of floorpan in way. I have Texas speed headers also.
Old Mar 31, 2013 | 11:06 PM
Cheap headers = BFH.
What does Texas Speed say about it?
Old Mar 31, 2013 | 11:31 PM
Mangled03gmc's Avatar
Baltimore Whore
Old Apr 1, 2013 | 09:08 AM
Vortec350ss's Avatar
If you dent just below the o2 bung it should angle it down just a hair... its worth a shot.
