nos?
Old Dec 6, 2003 | 02:44 PM
GoldenVelvet's Avatar
Nitrous is like a hot chick with an STD. You want to hit it but it could be dangerous. Its also addictive, just dont go over 100 shot untill you know what your motor is thinking.
Old Dec 6, 2003 | 04:35 PM
RacerBill's Avatar
i was goin to install the 5177 kit and i was wondering if neone has that setup....with edit.....where i could be told what to do b/c yeah....does neone kow if the 5177 is wet or dry? thanx for the posts
Old Dec 6, 2003 | 04:50 PM
blacksheep's Avatar
The 5177 is the dry kit I use. Just install the nossle before the maf and the computer will add the extra fuel that is need. No tuning should be needed if use a 100 shot or less, but if you have a HPP3 DO NOT use performance tuning.
Old Dec 6, 2003 | 10:33 PM
RacerBill's Avatar
thanx black sheep i was not going to run the tuning neways i really appreciate it ...i have one q though....i was wondering what else i might look for such as problems with running lean....how much should i look for it to speed me up in the 1/4..? thanx
Old Dec 7, 2003 | 12:42 AM
with a 60 shot I ran a 14.3. I would say 60 shot=.7sec
Old Dec 7, 2003 | 04:54 AM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
How do you spray before the MAF if you have a K&N?
I guess I could re-locate the MAF to right in front of the TB and fab a tube up and just install the nozzle in there
Old Dec 7, 2003 | 05:11 PM
BigKID's Avatar
I plumbed mine into the metal end of the filter. You do have to be carefull though, if you get the nozzle too close to the mafs it will freeze it and wig your truck out and the tranny will not shift properly untill it thaws out.
Old Dec 7, 2003 | 05:48 PM
Did that happen to your truck? How do you make sure it isn't "too close"?
What is "too close" anyway? Would 6 inches away be fine? That's why i was thinkin of making a custom intake tube and relocating the MAF.
Hmmm...
Old Dec 7, 2003 | 06:05 PM
I relocated my MAF. Six inches is the minimum safe distance. They also say you should de-screen your MAF but have never gotten a good answer as to why.
Old Dec 8, 2003 | 07:13 AM
BigKID's Avatar
Yea, 6" is the min safe distance. I was always right on the border with the filter that came with the kit. I know have a s&b (powershot type) filter. Although the overall filter is longer the place where I inserted the nozzle is closer to the meter. I engineered a longer tube to the filter that puts the nozzle about 10" from the meter and it works great now.
simman22
Jan 21, 2017 10:27 PM
natejk
Nov 15, 2016 08:05 AM
Steve Sr.
Aug 24, 2015 06:31 PM
bmbutler
Oct 23, 2004 11:44 AM
GREGGO
Feb 27, 2003 03:55 AM
