No AC controls when low fuel???
Old Dec 10, 2003 | 05:44 PM
mudz5.3's Avatar
Default No AC controls when low fuel???
Has anyone come across this yet? On the way home the window was fogged up and I couldn't turn the defrost on. The blower had different speeds, but no control of temp, just hot and no control of floor/defrost, just face. I can understand why, using the ac as needed consumes more fuel, just didn't think my truck would have that. Is this a fluke or has anyone else run across this???
Old Dec 10, 2003 | 05:49 PM
Flyer's Avatar
Something's up there ... check the vacuum lines that run into the motor from the cab.
EDIT .. Are these things even VAC operated anymore?
Old Dec 10, 2003 | 05:51 PM
mudz5.3's Avatar
Well thats what I thought at first, then it hit me that I will wait till I fill up. Filled up and everything worked perfectly, defrost, cold air, ac. I kinda think that if the ecm sees an extremely low amount of fuel, it will not allow the ac to kick on and block certain functions of the ac control panel.
Old Dec 10, 2003 | 11:23 PM
Flyer's Avatar
I don't have that problem. Even if it's low enough to trigger the low fuel waring.
Old Dec 10, 2003 | 11:42 PM
CashDudeHomie's Avatar
When my truck is cold, I can't use the dome light. Sometimes when I push the switch to dome, the CARGO light comes on. When the truck warms up a little everything goes back to normal. Also my gas gauge goes up and down all the time. We have haunted trucks
Old Dec 11, 2003 | 12:27 AM
Flyer's Avatar
Now that you mention about the cargo light .... Mine will flash on for about a half second when the interior map light is turned on.
thunder550
Oct 8, 2015 04:53 PM
GMCtrk
Jul 17, 2015 06:39 PM
jrplz
Jul 9, 2015 12:07 AM
davis28905
Jul 8, 2015 03:20 AM
