Nnbss/tbss
Old Jan 26, 2017 | 04:24 PM
Kodiak544's Avatar
Default Nnbss/tbss
When you guys say nnbss/tbss intakes what engines are you referring to? Trying to find some online but dont know want engines they come on. Thanks.
Old Jan 26, 2017 | 04:26 PM
ezdaar's Avatar
link to buy one
https://www.performancetrucks.net/fo...ectors-546596/
Old Jan 26, 2017 | 04:28 PM
ezdaar's Avatar
the intakes are on most, 08-13 GM truck/van/suv,
Identify them by the number of bolts holding the throttle body on..
Old = 3 bolts
New = 4 bolts
There are four types on 4 bolt intakes.
Return.
Returnless fuel rail, get the correct one for your ride.
and Square port.
Electronic controlled throttle body and Cable throttle body.
Match the new one to your old intake minus the bolt pattern on throttle body.
Old Jan 26, 2017 | 04:43 PM
Kodiak544's Avatar
I have a lm7 intake which part number or numbers or engines would work for my setup I'm going to put 243s on soon!
Old Jan 26, 2017 | 05:07 PM
arthursc2's Avatar
What year is your motor?
With a little creativity and plumbing, any cathedral port 08-13 manifold will work for you.
Old Jan 26, 2017 | 05:51 PM
Kodiak544's Avatar
2001 year model
Old Jan 26, 2017 | 07:28 PM
arthursc2's Avatar
Your fuel system is return. I would buy any 4 bolt intake you want from a Trailblazer SS, 08+ 4.8/5.3, a C5 fuel filter and this throttle body:
GM GEN LS1 LS2 LS4 LS6 LS7 92MM INTAKE MANIFOLD THROTTLE BODY PLATE ASSEMBLY SL | eBay
Old Jan 26, 2017 | 08:27 PM
10 Second Club
My truck is an 01', I am using an intake from a 2011 truck. I used a C5 Corvette fuel filter and a C5 fuel tank hose to connect everything. I tried one of the china-bay TBs, didn't work out for me, ended up with a NW 92mm. Got a throttle cable bracket from SDPC that works well. There are pictures of everything in my project thread.
Old Jan 26, 2017 | 08:57 PM
arthursc2's Avatar
Why didnt the cable work for you? Curious because I own 2 of the cable TBs from ebay, but havent run a single one yet. What am I in for?
Old Jan 26, 2017 | 09:16 PM
Kodiak544's Avatar
https://www.amazon.com/ACDelco-12580.../dp/B005QZQVR0Give me a link for your project I need a list of things I will need let mechanic handle to rest lol
