NNBS headers, y pipe and cam. Before and after Dyno's
Old Mar 31, 2017 | 12:40 AM
  #41
mikealicious2k5's Avatar
good to know. I'll see if I can measure that and look it up. thanks
Old Mar 31, 2017 | 11:09 AM
  #42
PathfinderJr's Avatar
Out of curiosity, how does that cam sound and how does it drive? Any vids of it?
Old Mar 31, 2017 | 03:28 PM
  #43
here's a vid of it idling, cutout open. It doesn't chop anywhere near as hard as I'd like. The current rpm in park is between 750-800.
people with cams, where do you guys normally idle? I was thinking about asking him to adjust it to 500 to get more of that rough idle.
I love the way it drives though. Noticeable power gains in part and full throttle.
Old Mar 31, 2017 | 04:13 PM
  #44
Atomic's Avatar
I have a gauge for that
The problem with a low idle is it is very unstable and susceptible to stalling, unless you are ok with it slowly getting down there, but it is still unstable.
Old Mar 31, 2017 | 04:18 PM
  #45
If the idle is only adjusted while the truck is in park, it shouldn't matter though right? The idle seems to change with I put the truck in drive, and it's under a small load.
I've just wanted a truck or car that "lopes" at idle so bad for so long, it was a little disappointment when this one didn't chop at idle. I just want a LITTLE bit of a chop. haha
Old Mar 31, 2017 | 07:59 PM
  #46
Atomic's Avatar
Yea, that is probably do able. There are a couple other ways, but the rpm is the easiest way.
Old Mar 31, 2017 | 08:27 PM
  #47
would the other ways be adjusting timing at idle?
Old Mar 31, 2017 | 08:34 PM
  #48
Atomic's Avatar
Timing, overspeed/underspeed correction, and afr would be other ways. If you have VVT you can play with that as well.
Old Apr 1, 2017 | 03:35 PM
  #49
Fast355's Avatar
Yes those things should help. I would imagine slightly retarding the cam at idle maybe 4-8° would close the intake valve later and give it more chop. Also if the Under/Overspeed timing was reduced ~50% it would also chop harder. I usually add to those on my cammed setups because I want to hide the cam as much as possible. Idling at 750 rpm you can barely tell my old 350 has a cam in it, much less a 218/228 on a 112° LSA. My 2006 Hemi ram had a 212/212 on a 114° LSA and sounded practically stock through the muffler at 650 rpm. Also you can reduce your idle spark down to about 12-16° and it will make it choppier as well.
Tuckin15s
Sep 12, 2013 03:26 PM
Silverado2469
Feb 29, 2012 05:25 PM
Whippled2dr
Feb 26, 2008 07:47 PM
CARAZYCUTER 4.8
30
Jul 7, 2004 04:10 PM
Jason99T/A
49
Oct 27, 2003 10:05 AM
