Nnbs: 4.3 to 5.3
Old Apr 22, 2012 | 05:56 PM
The_dealer's Avatar
Registered User
Default Nnbs: 4.3 to 5.3
I've been looking and searching for a while, and I can't find answers. I want to go from my 4.3 to 5.3. Can I use my stock trans? Do I need a different converter? And what years can I use the motor/wiring from? Everything I've found was for NbS or obs. I don't want to sell the truck. I've already started collecting parts for an sas. Don't know too much about the interchangeability on the newer Chevys. Looking for 300-375 Hp, mostly more torque. What do I need besides motor, wiring, PCM, intake tube and Maf? It will be getting a rebuild before its in, but I searched summit and couldn't find anything for the ls truck engines(as far as a rebuild kit) any insight?
Old Apr 23, 2012 | 05:26 AM
supercharged680's Avatar
https://www.performancetrucks.net/fo...-guide-378643/
Old Apr 23, 2012 | 07:03 AM
The_dealer's Avatar
Registered User
I saw that, but mines a nnbs. I wasn't sure if anything was different between NbS swaps and nnbs. What year motors can I use?
Old Apr 23, 2012 | 10:54 PM
You need to forget piecing something together and go hit a salvage yard and buy a complete low mileage pull out. 08-12 are the only years you can use for your swap. You can change the bellhousing and torque converter and keep your existing transmission. The engine harness and pcm/tcm need to be the exact year model your truck is to avoid beating your head against the wall chasing gremlins. Get the exhaust front to back outta the donor.
Or save yourself the frustration downtime and cash and trade it and buy a v8 then mod it. You'll be money ahead unless you can find a donor truck to rob all the odds and ends off of.
Old Apr 24, 2012 | 05:53 AM
The_dealer's Avatar
Registered User
I've already spent too much on it to trade in for a new truck. I thought I could use my current PCM/tcm with a tune
TAPyvehc93
Dec 27, 2015 12:14 PM
Duramaxin14
Sep 12, 2015 08:04 AM
sTNT971
Sep 11, 2015 02:38 AM
11MPG
Sep 10, 2015 08:34 PM
11MPG
Sep 8, 2015 04:52 AM
