nitrous for radix supercharger
Old Oct 7, 2003 | 09:33 PM
gr8twhite's Avatar
Default nitrous for radix supercharger
Has anyone put a nitrous system on a radix supercharged 5.3.If so,how did you do it? Intake tube or through the injectors.
Old Oct 7, 2003 | 09:43 PM
BlownChevy's Avatar
blownerator
25 Year Member
Default Re: nitrous for radix supercharger
Go with a smaller pulley, safer and cheaper.
www.projectrwear.com
Old Oct 7, 2003 | 11:04 PM
gr8twhite's Avatar
ok,what size do you reconmind? I have a 3.40 pulley on mine.
Old Oct 8, 2003 | 03:16 AM
Flyer's Avatar
3.2 and if no KR try a 3
Be sure to watch for KR though.
Welcome to the boards BTW
Why don't you let us in on what you got going on there.
Old Oct 8, 2003 | 12:54 PM
gr8twhite's Avatar
Thank you,im glad to be here.What is KR? I have a 2000 Silverado 5.3 auto. With a radix,true dual exhaust with 2 21/2in flowmaster delta force mufflers,no cats,o2 sims,jet scu2000,flex a lite fans,4.10 with eaton e-locker.I changed the small heat exchange ratiator to a perma cool 6 pass oil cooler with a 1250cfm fan.Headers and a stall are next.
Old Oct 8, 2003 | 02:08 PM
Banned
sounds like you've got a decent setup going already, KR is KNOCK RETARD....it will blow up your motor. can, has, and will again!!!! get ya some ASM headers and a PY3600E converter and you're set. i think it is best to go with a direct port system like the holley setup that clicks under the injectors for use with the radix
Old Oct 8, 2003 | 10:42 PM
gr8twhite's Avatar
Thanks,she's pretty quick.Where can i get some ASM headers,are they long tubes or shortys?I checked the holley nos setup before,but thats alot of money.$1000 if i remeber right.
Old Oct 8, 2003 | 10:47 PM
BlownChevy's Avatar
blownerator
25 Year Member
I know of one place you can get the ASM's!
Old Oct 9, 2003 | 06:00 PM
gr8twhite's Avatar
I should have known that.I think i will get a 3.2 pulley and see what happens.What exacly is KR?Will it throw a code before it goes or will it without warning.This is a little new to me because im use to carbs and not EFI.Thank you for helping me out.
simman22
Jan 21, 2017 10:27 PM
moregrip
Jul 26, 2016 11:21 AM
bagged7104SS
Sep 24, 2015 08:42 PM
gavin2005
Sep 13, 2015 09:04 PM
06murder
Sep 4, 2015 03:54 PM
