nitrous for radix supercharger
Go with a smaller pulley, safer and cheaper.
www.projectrwear.com
3.2 and if no KR try a 3
Be sure to watch for KR though.
Welcome to the boards BTW
Why don't you let us in on what you got going on there.
Thank you,im glad to be here.What is KR? I have a 2000 Silverado 5.3 auto. With a radix,true dual exhaust with 2 21/2in flowmaster delta force mufflers,no cats,o2 sims,jet scu2000,flex a lite fans,4.10 with eaton e-locker.I changed the small heat exchange ratiator to a perma cool 6 pass oil cooler with a 1250cfm fan.Headers and a stall are next.
Banned
sounds like you've got a decent setup going already, KR is KNOCK RETARD....it will blow up your motor. can, has, and will again!!!! get ya some ASM headers and a PY3600E converter and you're set. i think it is best to go with a direct port system like the holley setup that clicks under the injectors for use with the radix
Thanks,she's pretty quick.Where can i get some ASM headers,are they long tubes or shortys?I checked the holley nos setup before,but thats alot of money.$1000 if i remeber right.
I should have known that.I think i will get a 3.2 pulley and see what happens.What exacly is KR?Will it throw a code before it goes or will it without warning.This is a little new to me because im use to carbs and not EFI.Thank you for helping me out.
gavin2005
Sep 13, 2015 09:04 PM
06murder
Sep 4, 2015 03:54 PM
