which nitrous kits ara you running
Old Oct 5, 2003 | 03:45 PM
one03sierra's Avatar
Formerly one92rs
Default which nitrous kits ara you running
which nitrous kits are you running and how much are you shooting.75-100-150.i do have stock internals. and where did you get your kit.
Old Oct 5, 2003 | 07:49 PM
goshawk23's Avatar
Truck addict
Default Re: which nitrous kits ara you running
i'm sure if you look around you might can piece a kit together for cheaper than buying the whole thing. bottles are expensive tho. so definantly try to find a used one.
Old Oct 5, 2003 | 10:02 PM
v8
17,16,15,14,13,12,11 Drvr
look at E.T.PERFORMANCE.COM, THERE IN PASEDENA OFF OF PRESTON AND SPENCER THEY SELL AND INSTALL, DECENT PRICES
Old Oct 5, 2003 | 10:35 PM
parish8's Avatar
single digit dreamer
i have the NX kit and recomend it. i have sprayed as much as a 100shot on top of 9psi(stock 6.0). most say 125 is a safe shot, once you upgrade your fuel system and start monitoring it closely i'd say a 150/175 is prety safe still.
you can find a basic kit used for $300 or less, i got mine for $525 with a heater, window switch, gauge, jets and pills.
Old Oct 5, 2003 | 10:39 PM
Hit Man X's Avatar
Yeah the NX kit is the best kit available on the market. Just their entire setup is a setup above the Nitrous Oxide Systems' kits. I have used a NOS kit in the past as was my first time using nitrous. It was good but their openers are not the greatest, heaters aren't very exact, etc. I'd take a cheap NOS kit but my choice is NX.
Hell my DMax will have an NX kit on it...after I get some big injectors in it.
Old Oct 6, 2003 | 09:39 AM
BigKID's Avatar
I have a BigKID brand kit. I used pieces and parts to build mine. I have a Luxfer bottle, NOS highflo valve, generic braided line, NOS powershot solinoid, and ??? nozzle with a .052 jet. That comes out to about a 100 dry shot.
Old Oct 6, 2003 | 10:09 AM
oxidizr's Avatar
Moderator / Sponsor
They make kits?
I've always assembled pieces and as far as solenoid design goes they are identical from manufacturer to manufacturer. They only real difference is the size of the solenoid magnet, plunger and internal orafices. If you compare a SuperPowerShot to a standard NX the NX out flows it. If you compare a NOS Cheater to the NX standard the Cheater out flows it. All smoke in mirrors ... just marketing games ... like TNT systems makes "more" power than the rest ... hmmm, how is that possible ... do the same principles of physics apply?
For 100 hp you shoould be fine with NOS, NX, TNT, Nitrous works, after all they are really about 80% the same... only proprietary components are bottle valves and nozzles.
Old Oct 6, 2003 | 10:36 AM
yellowls1truck's Avatar
im running a n.o.s. 5177 kit. it is made for the ls1 f-body, but it will work fine on the trucks too. whatever setup you have just remember that you need to keep good bottle pressure and to use as many precautions as you can.{w.o.t. switch, fuel pressure switch..ect.} and dont get to carried away with the big h.p. shot, be somewhat conserative. unless you like buying new transmissions and such.
stealthperf
34
Feb 14, 2016 11:35 AM
thunder550
Oct 8, 2015 04:53 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
slowlsx
Jul 13, 2015 04:18 AM
