New times with SS3800!
Old Nov 29, 2003 | 11:30 PM
Black Blown 02's Avatar
Default New times with SS3800!
I finally fixed my exhaust leaks and boost leaks and got to G-tech the truck with the SS3800.
Previous best 4" pulley- seeing 8psi 14.8 at 92 with stock verter
3.6" pulley-seeing 10psi 15.1 at 91 with TT3000(bad boost leak and tranny was on the way out)
Fixed boost leak, installed FLP level4, and SS3800-seeing 11psi 14.06 at 97.
This is with the old G-Tech which is usually within .05 and 2mph faster when I've compared it to the track.
So I could probably say 14.1 at 95 would be close.
Judging from MAF readings, I gained about 120hp at the bottom of the shifts just from the shift extension of the SS3800!
I'm seeing 50lb/min at 5800 and 40lb/min at 4900(bottom of shift)
The SS3800 is an awesome converter for the ATI!
BTW- these times are at 5000ft elevation.
I'm only seeing about 11 degrees of timing without ant KR, so I think I could benefit from about 4 more degrees.
Old Nov 29, 2003 | 11:39 PM
Hit Man X's Avatar
Damn, running pretty strong! Think a set of LT's would help the bottom end power?
Old Nov 30, 2003 | 10:03 AM
Yeah, longtubes probably would help my lowend. I don't know if more bottom end would help me now though. The lowest rpm I see is 4200 at launch. Then 4900 at the bottom of my shifts.
I got the shorties before I got on this board and didn't know better.
Old Nov 30, 2003 | 09:29 PM
I think I need the new G-Tech like Parish has.
I went out today and ran a 13.5 at 102
Then noticed it was tilted just a bit. Leveled it out and ran a 14.0 and 14.1 at 97.
thunder550
Oct 8, 2015 04:53 PM
kr1s
Aug 24, 2015 05:34 PM
smokeshow
Aug 23, 2015 08:23 PM
therock
Aug 23, 2015 01:37 PM
