new question
Old Apr 17, 2006 | 01:26 AM
Matt_Critt's Avatar
Question new question
ok, i misunderstood my brothers question. he wants to know what it will take to swap a carburated 350 into his 95 k1500 with a 5.7. will it affect the tranny at all, if so what needs to be done to get it to work properly.
thanks
Old Apr 17, 2006 | 01:28 AM
Derek @ EDO's Avatar
FormerVendor
a 350 is a 5.7
Old Apr 17, 2006 | 03:15 AM
SnakeOiler's Avatar
The only difference you are talking about is really swapping the intake/tbi setup for an intake/carb setup. you definitely will have some issues, because you need to disconnect the TBI - the tranny might be an issue because it could be using signals from the TBI connectors.
Perhaps someone here could point you in a better direction.
Old Apr 17, 2006 | 04:17 PM
erronisme's Avatar
eldebrock makes an intake manifold that is already to go for the swap.
You still use your old TB for the TB plate and sensors, but the injectors are at the end of each intake runner. I think the only thing that you need after that is a larger fuel pump.
Old Apr 17, 2006 | 09:38 PM
Yelo's Avatar
there a re abunch of aftermarket controllers for the tranny out there.....alot of guys have pulled the electronic mumbo-jumbo out, thrown a set of Auto-meter gauges in, plugged in a tranny controller and called it good....
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
