New motor Question?
Old Feb 17, 2012 | 10:30 PM
GMCDee's Avatar
Default New motor Question?
My new engine showed uo today and it seems to be alittle diffrent then the one i have intake and throttle body are diffrent, Did the LQ9 come with a cast iron block?
Old Feb 17, 2012 | 11:06 PM
mcfarlnd's Avatar
Un-Registered User
Any pics? What were you trying to order? What year do you have to compare it to? Yes the Lq9 is iron
Old Feb 18, 2012 | 12:26 PM
GMCDee's Avatar
Ill get some pics here shortly. Mine came out of a 2000 2001 HD,Come to find out this one came off a 2005 2006 caddilac SUV its drive by wire diffrent fly wheel. Factory specs were something like 345 HP 380 LB TQ. Got a steal on this motor guy didnt know what he had it came fully dressed so just have to change cam springs injectors. Im worried the tune will be off since this motor supposbly has higher compression and what not. Will i need to retune if this turns out to be a higher compression 6.0????
Old Feb 18, 2012 | 12:28 PM
GMCDee's Avatar
Default Old Motor!!
Old Feb 18, 2012 | 12:34 PM
GMCDee's Avatar
Default New Motor!
Old Feb 18, 2012 | 12:36 PM
GMCDee's Avatar
It also came with the newer round coil packs mine were square not to sure it makes much diffrence but newer anyway.
Old Feb 19, 2012 | 08:23 AM
azchevydude's Avatar
It is the higher compression 6.0. A re-tune might be a good idea
Old Feb 19, 2012 | 08:26 AM
La Blue 05's Avatar
Yeah I would do a retune
Old Feb 19, 2012 | 12:00 PM
GMCDee's Avatar
Hopefully should see alittle more Umphhh then. Wasnt to plzd with my old 6.0. I might wanna go alittle bigger on the cam though tr228 is what im looking at now should be solid in this new engine. Thanks for the help Gents
Old Feb 19, 2012 | 12:41 PM
dmelvin's Avatar
I think your cam you were running on the LQ4 may have been part of the reason you weren't too happy with it. That cam would be a decent all around cam for a 5.3, for a 6.0 it should have had plenty of grunt down low, but probably fell off a bit up top. I think you'll like a TR/TSP 224 or 228 a lot better. Best bet would be to get Pat G. to spec and grind you one.
