New injectors
Old Feb 14, 2006 | 06:13 PM
virgils4.85spd's Avatar
Default New injectors
I have a 2001 4.8 5spd with 114,000 on the stock injectors. Will i see any gains from new injectors? Maybe higher psi, although im n/a with a tune, or do the stock ones do just fine?
Thanks,
Derek
Old Feb 14, 2006 | 08:10 PM
v8
17,16,15,14,13,12,11 Drvr
If you haven't had them cleaned then do that, it will help you alot.
Old Feb 14, 2006 | 09:50 PM
Default Pita??
Is it a pain to clean them. I usually run 93 and octane booster and injector cleaner once a month. I know its not like a thorough cleaning but is it really worth it to take them out and clean them?? Is it a pain to do?
Thanks,
Derek
Old Feb 15, 2006 | 12:16 AM
Yelo's Avatar
I've never thought a couple of bottles of injector cleaner was too much of a pain in the *** to do....you could take 'em out and have them sonically cleaned but as long as you run a bottle of Sea Foam through them once in a while they're probably as clean as they'll get
Old Feb 15, 2006 | 08:08 AM
Default Aighty
I was jw about manually cleaning them, but if the injector cleaner or sea foam works, then im in good shape.
Thanks,
Derek
$A_Money$81
Mar 27, 2023 10:25 AM
shootermwc
Oct 8, 2015 01:45 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Wrecker 426
Sep 29, 2015 11:00 PM
sTNT971
Sep 26, 2015 04:22 PM
