new guy with problem
Old Dec 21, 2004 | 07:51 AM
procharged hd's Avatar
if i rember right the fmu lines will fit only one way theres a small line and a big line. when i adjust the fmu i can see it in the guage so it must be doing something
Old Dec 21, 2004 | 03:21 PM
Chevmann99's Avatar
I think the best advice your gonna get is to dump that FMU and get injectors and a tune, best thing I ever did since adding the charger. You will also have to upgrade to a 255L high pressure/volume fuel pump, I used a Walbro GSL392. The ProCharger pump is good for high pressure but can't push the volume needed for 43LB injectors at high RPM's. Very worth while mod. Here is a copy of my Dyno run with the FMU and stock injectors you can see the AF is all over the place. I have not re-dynoed yet, but the 300 deg drop in WOT exhaust temp tells me that it is way better. Used to see 1500+ deg at WOT, never gets above 1200 now.
Old Dec 21, 2004 | 11:38 PM
lm7's Avatar
lm7
try a thicker gauge wire...the samml green one was the one that DIDNT work for me..and stop flooring your truck its running dangerously lean...until you figure it out...invest in the injectors and tuning its well worht the money..but for now splice a thick gauge wire that runs off ignition...i ended up splicing a htick pink wire....
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
