new guy with problem
Old Dec 19, 2004 | 08:35 PM
procharged hd's Avatar
Default new guy with problem
installed procharger on stock 6.o when it s pulling vaccum runs fine but as soon as it hits zero on the boost guage it falls on it face till about 4lb of boost and befor i put the procharger on i mad a homemade air intake and it did the same thing i changed the mass air senser and did not make a defference NEED HELP
Old Dec 19, 2004 | 10:08 PM
BlownChevy's Avatar
blownerator
25 Year Member
Sounds like a tuning issue....who tuned it?
Old Dec 19, 2004 | 11:30 PM
Flyer's Avatar
Stock tuning ??
Old Dec 20, 2004 | 12:57 AM
lm7's Avatar
lm7
is your inline pump working properly?
Old Dec 20, 2004 | 07:52 AM
the truck has stock tunning its weard when u lay into it its just doggy real bad and u can hear it through the exhaust that it kinda surges a little bit u can let off and it wants to take off and i have messed with the fmu and it didnt make a defference but like i was saying as soon as it hits about 3 or 4 lb it runs good
Old Dec 20, 2004 | 08:14 PM
Any Ideas??????
Old Dec 20, 2004 | 08:32 PM
XLR8NSS's Avatar
Adkoonerstrator
Definately sounds like a tuning problem. I'd almost bet that FMU is not working correctly until it sees 3-4lbs of boost. What you are describing is similiar to what would happen with my car when the inline pump wouldn't activate right away because of a faulty pressure switch. The car would surge a little until the pump came on and stabilized the fuel pressure. I've also used FMU's before and they're not the most reliable things.
The first thing you should do is find someplace that can check the air fuel ratio with a wideband or at the very least find someone with a scanner that can monitor your 02 readings at WOT. That would go a long way in helping diagnose your problem.
If it is a problem with the FMU your best bet would be to get bigger injectors and a tune for them and the supercharger.
Old Dec 21, 2004 | 01:07 AM
lm7's Avatar
lm7
get ASM 43 lb injectors and make sure your inline pump is wired right....when i first installed my kit i wired it wrong and it pulled enouhg power to run... so the test light would come on there was current running to it but it wasnt enough to push the pump....make sure triple check everyhting il bet its that it sounds exactly like what my truck would do....it gets loud as **** but goes no where.....your leaning it out really bad get those injectors and make sure the pump is working it will feel like a new truck...youll need ls1edit or some kind of tuner to tune the big injectors in.
Old Dec 21, 2004 | 01:39 AM
PappyDan's Avatar
Tribe Shaman
i know of only one other time, and i hope you did not do what he did?
being in a hurry, looking at the picture only to see what it should look like but faled to read, did you happen to put the lines on the fmu backwards?
Old Dec 21, 2004 | 07:34 AM
i wired the pump to the little green wire with a tracer does that sound right???? i also used a test light it worked when i turned the key on but, the wire looked really small.can anybody rember what they wired theres to??
