New cam time. Opinions needed
Old Apr 28, 2007 | 08:33 AM
VicRed's Avatar
Default New cam time. Opinions needed
The time has come for me to swap cams again. Ive just gotten bored with my TR224. Ive been looking at the new Texas Speed Torquer v.3 231/234 .643"/.598" 112 LSA. My friend just installed that cam in his bolt on M6 98'Z28 and went from 322hp to 378hp with tuning. On the site it shows a power band from 2300-6700. Im still running the stock truck intake with 241 heads and long tubes. My converter flashes to around 3800rpms so im not too worried about the low end suffering a bit. Any other suggestions? Im looking to do this fairly soon.
Old Apr 28, 2007 | 09:00 AM
gonzo 6.2's Avatar
Were is you list of mods?
Old Apr 28, 2007 | 09:53 AM
VicRed's Avatar
Main mods include.
98 LS1 swap
241 Heads
TR224
Crane dual valvesprings with tit. retainers
ARP rod bolts
Pacesetters
ported TB
Vig 3600
125 shot
Right now my shift points are set around 6500.
Best 1/4 mi. N/A is 12.9 @ 104
on gas is 11.81 @ 114
Old Apr 28, 2007 | 10:17 AM
Quik's Avatar
5 year bitches!
swap over to the ls6 intake and run the TV2. i had that one not to familar with the TV3 but i ran the TV2 before and it was a nice piece
Old Apr 28, 2007 | 10:46 AM
Sport Side's Avatar
I vote swap out the heads.
Old May 4, 2007 | 09:47 AM
VicRed's Avatar
Just picked up some DART 225s. Next will be an LS6 intake along with 4.10s....
Old May 4, 2007 | 10:05 AM
Sport Side's Avatar
Good! Good choice. I didn't like the idea of going with a larger cam because you were 'bored' of your 224. LOL
Again, good choice of going with heads instead of increasing the cam size. Sometimes, going with a larger cam like that might not start increasing power until after 4800 RPM. Your stating your converter flashes to 3800, but you could have lost a lot of TQ inbetween 3800-4800. Those heads should pick up across the board, but of course more so at higher RPM.
Old May 4, 2007 | 12:15 PM
zippy's Avatar
I'd go with the XR281HR cam for that setup. Much bigger than that isn't going to do much good until you change the intake manifold.
Old May 4, 2007 | 12:53 PM
virgils4.85spd's Avatar
Default Id like first shot at that 224
if you dont mind, i would like first shot at the 224. How many miles are on it?
Thanks,
Derek
Old May 7, 2007 | 12:50 AM
VicRed's Avatar
So you think I should just keep the 224 with the new heads and LS6 intake?
I figured now would be the right time to swap cams to something a little bigger/better since I'll already have her torn apart. Although I do realize bigger is not always better.
