New Bolt-up Build
Old Feb 7, 2006 | 09:47 PM
AintNoHo's Avatar
Default New Bolt-up Build
Like many guys here currently, I'm working on my new build. Using my Gen 1 engine in my sig, I'm going for more power at rpms. My truck already has tons of torque but not enough horsepower and only to about 5000-5400. So here's my fix:
AFR 195 COMP 74cc heads - on order, 4 more weeks I hope
Edelbrock Victor EFI intake - got it, cleaning it up with the dremel
Holley 1000 cfm 4-barrel throttlebody - got it
Hooker 1.75 long tube headers - got em
NOS Square-bore Plate - got it
Vortech V-7 YSi - on order, 2 weeks I hope
Schneider Cam 244*/244*@.549 112LSA - got it
Ran this set-up on Desktop Dyno and it should be killer at 15lb boost even without nitrous. I'm also shopping on a 4L80E and a Ford 9 inch. I know most of you guys are LS1 and into a turbo or a Radix-Whipple-Magnusson type charger but I thought I'd stick with what I know.
I have 1 question though. With the 74cc heads to keep 8:1 cr, I need to either mill them or use a .015 gasket. Which would you do?
Old Feb 7, 2006 | 10:39 PM
JimS's Avatar
I don't think a thin gasket is wise on a supercharged engine. But what do I know?
Old Feb 7, 2006 | 11:23 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Mill the heads. You want a little thicker head gasket for better sealing since there are some inperfections on the block deck and the head deck. The smallest I have seen someone go on headgasket thickness is .025 personally.
Old Feb 7, 2006 | 11:39 PM
Okie5.3's Avatar
o-ring'em
Old Feb 7, 2006 | 11:50 PM
Originally Posted by Okie5.3
o-ring'em
I am with Okie, after o-ring you should be able to use a regular thickness gasket.
Old Feb 8, 2006 | 12:36 AM
AintNoHo's Avatar
o-ring'em
Thanks, I didn't even think of that. Summit has Felpro .015 head sets but that did seem a little lacking.
Old Feb 8, 2006 | 12:55 AM
1slow01Z71's Avatar
IMO cometic is the only way to go that or the SCE titan head gaskets they are the best. Some get away with stock MLS headgaskets but I would get the better ones dont skimp on the stuff you really need to be strong.
MOBBN
Sep 22, 2015 08:07 PM
2500ZL1
Sep 12, 2015 03:50 PM
MA$TER_E
Sep 9, 2015 03:14 PM
iregret
Sep 7, 2015 01:20 PM
