New Bolt-up Build
Like many guys here currently, I'm working on my new build. Using my Gen 1 engine in my sig, I'm going for more power at rpms. My truck already has tons of torque but not enough horsepower and only to about 5000-5400. So here's my fix:
AFR 195 COMP 74cc heads - on order, 4 more weeks I hope
Edelbrock Victor EFI intake - got it, cleaning it up with the dremel
Holley 1000 cfm 4-barrel throttlebody - got it
Hooker 1.75 long tube headers - got em
NOS Square-bore Plate - got it
Vortech V-7 YSi - on order, 2 weeks I hope
Schneider Cam 244*/244*@.549 112LSA - got it
Ran this set-up on Desktop Dyno and it should be killer at 15lb boost even without nitrous. I'm also shopping on a 4L80E and a Ford 9 inch. I know most of you guys are LS1 and into a turbo or a Radix-Whipple-Magnusson type charger but I thought I'd stick with what I know.
I have 1 question though. With the 74cc heads to keep 8:1 cr, I need to either mill them or use a .015 gasket. Which would you do?
Mill the heads. You want a little thicker head gasket for better sealing since there are some inperfections on the block deck and the head deck. The smallest I have seen someone go on headgasket thickness is .025 personally.
IMO cometic is the only way to go that or the SCE titan head gaskets they are the best. Some get away with stock MLS headgaskets but I would get the better ones dont skimp on the stuff you really need to be strong.
MA$TER_E
Sep 9, 2015 03:14 PM
iregret
Sep 7, 2015 01:20 PM
