Need some help with tune and e-fans
Old Aug 10, 2004 | 03:44 PM
abbo7's Avatar
Default Need some help with tune and e-fans
I had Allen tune for my e-fans, but I have not hooked it up so the PCM will run the fans. I am still letting the Flex-a-lite VSC controll them. However, I have some free time and want to hook the PCM to the e-fans. How do I go about it, would I use the VSC as a relay somehow?
Old Aug 10, 2004 | 05:21 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I would ditch the VSC and electronics from Flex-a-lite altogether. Allen makes a relay kit that plugs into PCM blue #42 for fan one and taps the A/C signal for fan two.
You can easily convert that kit to dual pcm driven fans (both on at the same time) by attaching the wire that hooks up to the A/C lead to the white wire on the PCM relay and the ground wire on the A/C relay to the PCM pin 42 wire.
thunder550
Oct 8, 2015 04:53 PM
06 4.8
Aug 21, 2015 11:33 PM
JFortner5
Aug 20, 2015 06:13 PM
Ls3silverado
Jul 31, 2015 04:22 PM
oharajo
Jul 18, 2015 09:24 PM
