Need more power
Old Jan 26, 2013 | 12:03 PM
  #31
Chrged5spd's Avatar
Originally Posted by darnie
your better off going with a TBSS or NNBS intake over the fas... its not worth the money IMO
I think i might run a bigger TB cuz if i run a bigger intake itd be stupid to run my stock Tb right?
Old Jan 26, 2013 | 12:34 PM
  #32
Sexyrado327's Avatar
I would say so I mean once your doing the transition you might as well. Just start looking into the dr. X link you'll need it to hook up your bigger throttle body from a 8pin to a 6 pin
Old Jan 26, 2013 | 01:53 PM
  #33
darnie's Avatar
ya exactly ull just need a x-link but i think u can run a 90mm tb with it?
Old Jan 26, 2013 | 02:00 PM
  #34
You could run upto the 102mm throttle body on it I'm sure once it has the x link
Old Jan 26, 2013 | 02:14 PM
  #35
darnie's Avatar
ya but wouldnt you need the intake ported? jw.... im still running my stocker TB
Old Jan 26, 2013 | 02:48 PM
  #36
Idont think you would need to but it would be beneficial to have a ported maniforld
Old Jan 26, 2013 | 04:51 PM
  #37
Chrged5spd's Avatar
So if i get a ndss/tbss intake and a 90mm tb they wont bokt together wats and x-link....yall are make me feel damn stupid haha but i thank u dor the help like i said im new to this ****
Old Jan 26, 2013 | 05:07 PM
  #38
darnie's Avatar
ya thats what i would do... i was going to do that , but the guy who did my heads made me a custom intake that matched my heads.
Old Jan 26, 2013 | 05:21 PM
  #39
if you get it you'll need a throttle body that's a 4 bolt connection. Your stock TB is a 3 bolt connection. They do sell the 4 to 3 bolt adapters but if your gonna waste your money on an adapter it might as well be for a bigger 4 bolt TB. After that's good you'll need a dr x link which is about 230 buks to connect from your factory 8 pin connection to the newer 6 pin connections. I'm pretty sure that's how all bigger TB are I just installed a factory 87mm one and needed the x link
Old Jan 27, 2013 | 07:55 AM
  #40
Chrged5spd's Avatar
wat about coils? And if i end up running a 400rwhp. Wat do u giys think my injectors should be? Will msd ignition gain anything?
