Need more power
#31
#39
if you get it you'll need a throttle body that's a 4 bolt connection. Your stock TB is a 3 bolt connection. They do sell the 4 to 3 bolt adapters but if your gonna waste your money on an adapter it might as well be for a bigger 4 bolt TB. After that's good you'll need a dr x link which is about 230 buks to connect from your factory 8 pin connection to the newer 6 pin connections. I'm pretty sure that's how all bigger TB are I just installed a factory 87mm one and needed the x link
#40
