Need HPTuners help.Timing dip at launch..
Old Nov 19, 2004 | 01:19 AM
Ryan23silverado's Avatar
7.50g/cyl??? the table only goes to 1.2g/cyl
Grams per Cylinder is figured by: [(grams per second) x 15] / engine RPM
Here is one of my older timing tables just for referrence on the lower rpm numbers (i'm boosted too, so you can get away with more -be aware of knock):
Old Nov 19, 2004 | 08:48 AM
marc_w's Avatar
Here is my latest table.
I was way wrong - I'm only at the mid-teens down low - I looked at a log and thought I was set to 20 down there.
I just looked at one of my runs at the strip, and I'm actually getting something very similar... I just never paid any attention to it.
Here's it is...
This was before headers... and I cut a 2.13 at full street weight and near full tank of gas. I thought that was fair, so I never looked into the timing dip.
Old Nov 19, 2004 | 09:08 AM
ktmrider's Avatar
Are the 03+ trucks running drive-by-wire TB's? If so maybe the electronics are not reacting fast enough when snapping the throttle wide open from idle. I know my father's 04 Furd and my 03 Hemi does not have the crisp throttle response that the cable/TPS system has. Just a thought...
Old Nov 19, 2004 | 09:12 AM
marc_w's Avatar
Yeah, 03's are running DBW... Mine definitely has nice sharp throttle responce, but I'm not sure about how quick it's opening vs a standard cable TB. You can get an idea of how mine opens - it's the green line in my scan above...
Old Nov 19, 2004 | 09:17 AM
Black Blown 02's Avatar
I have an 02 with a cable throttle and the same timing problem.
Old Nov 19, 2004 | 05:20 PM
MagRagC5's Avatar
I have HP also and have the same problem. Are you throwing a code 101 MAF error? I was and changed the code trigger values- it seems to have worked SOTP, but I haven't mapped it since.
Ed
Old Nov 19, 2004 | 10:20 PM
speedy02's Avatar
Originally Posted by speedy02
At the timeing dip it's at 7.50g/cyl..
Oops,I was wrong.It's at 0.63g/cyl.. Im going to try playing with the High octane timeing table a little and see if that works.When would i have to use the low octane timeing table?Dont it read off that table if you get bad gas or alot of knock?
Mark_w for some reason i cant see the tables in the links..I get "Unable to load graphics conversion filter".I would like to see them.
It's throwing no code.
Old Nov 25, 2004 | 07:03 PM
Did you figure this out on your timing yet?
Old Nov 26, 2004 | 02:39 PM
speedy02's Avatar
I have been adding a little timeing to 60-72g/cyl to 2000 rpm at a time and it looks a little better..But, Im still getting the timeing dip..What would smoothing do?
Porscharu914
14
Jan 20, 2016 10:45 AM
Avalanche2002
Nov 30, 2015 07:31 AM
legerwn
56
Nov 15, 2015 10:21 PM
97_ek
Sep 23, 2015 09:16 PM
