Need help with my 5.3 to lq9 swap
Old Oct 11, 2015 | 09:56 PM
  #61
Wolftrk99's Avatar
Take a pic at an angle looking back towrds the yoke/balance ring, if you can...
Old Oct 11, 2015 | 10:59 PM
  #62
derocafela_1's Avatar
Registered User
Old Oct 11, 2015 | 11:07 PM
  #63
Wolftrk99's Avatar
Yeah that is jammed up against and inside the seal, holy ****!!! If you have a long punch or chisel, or even a fairly large screwdriver you dont care much about put it againts the closest part of the yoke you can to the tailshaft housing and take the biggest hammer you have and knock the crap out of it...
Old Oct 11, 2015 | 11:09 PM
  #64
Wolftrk99's Avatar
Anything outside the black ring will defeat the purpose its a rubber dampener that allows the outer part to flex to absorb vibrations, same as a harmonic dampener wuld on a crankshaft!!
Old Oct 11, 2015 | 11:31 PM
  #65
Registered User
Thanks I'll try that tomorrow after work, I'm wondering if this happen because it got rear ended, when I bought the motor and Trans from the wrecking yard the guy told me that it was hit from behind, I also asked if he had the rear end he said he did but that it was damaged from the wreck .
Old Oct 11, 2015 | 11:44 PM
  #66
Wolftrk99's Avatar
Possibly, that or it got shoved in when they pulled the engine and trans...
Old Oct 12, 2015 | 06:42 PM
  #67
Registered User
Balance ring ended up breaking,
Old Oct 12, 2015 | 07:20 PM
  #68
Wolftrk99's Avatar
Good now you can actually hit the yoke, bit im beginning think that was fron being rear ended...
Old Oct 12, 2015 | 07:21 PM
  #69
Wolftrk99's Avatar
Do you have air tools???
Old Oct 12, 2015 | 08:08 PM
  #70
Registered User
Finally came off hitting the yoke, how can I tell if it was damaged? Will my yoke out of my 2000 4l60e work? Here are some pics.
