Need help 2006 6.0 random missfire on cylinders 1 and 8 possible cam and lifter swap
Old 04-11-2012, 01:20 PM
13 Second Truck Club
grey matter 04's Avatar
Originally Posted by pmgm
I did plugs and wires. I also swapped coilpacks around to, almost forgot I switched the injectors around to,to see if it would move the miss stayed in the same cylinders 1 and 8.. I don't know what else to check..,.
if u did all that and the miss is still present on those cylinders i would check compression n leak down could be a weak cylinder
Could be a valve issue or ring issue
Old 04-11-2012, 09:14 PM
pmgm's Avatar
Gotcha... I will be checking that this weekend...
ARC
57
02-21-2022 10:54 AM
OHsixLS3
12-27-2016 09:30 AM
GrooveCityZ71
08-31-2015 12:05 PM
Suburban2500
07-19-2015 04:50 PM
GRRR65GTO
07-10-2015 08:27 PM
Quick Reply: Need help 2006 6.0 random missfire on cylinders 1 and 8 possible cam and lifter swap
