Need Engine Tips
Old Mar 22, 2009 | 09:21 PM
CaLI87's Avatar
Default Need Engine Tips
I have 04 reg cab silverado 4.8 with Headers, K&N intake X pipe Cutouts and pulley, oyea and tune. I want to put a cam what do I have change on the engine and what kind of cams are good??
Old Mar 22, 2009 | 09:34 PM
nonnieselman's Avatar
automatic or manual transmission?
if you search you can find a ton of info on this... its covered a few times a week.
Old Mar 22, 2009 | 09:37 PM
CaLI87's Avatar
Automatic... yes am a newb you can't start knowing everything.
Old Mar 22, 2009 | 10:03 PM
budhayes3's Avatar
PT's Slowest Truck
Alot of cam options depending on your goals and what your future mods include (ie higher stall torque converter, heads...FI ), as for what you should change, I'd say get upgraded valve springs (which ones depend on how wild you go on the cam), hardened pushrods, and a cam install gasket kit from someone like SDPC or Texas Speed, it includes all of the affected gaskets and a new crank bolt (the bolt is torque to yield and should not be reused). You'll need new coolant and I'd do an oil change after the swap also.
Old Mar 23, 2009 | 10:03 PM
CaLI87's Avatar
Thx man ^^ good stuff
Corvette454l88
Sep 1, 2016 01:24 AM
Stainless Works
Nov 20, 2015 08:55 AM
TX Tahoe Z71
Sep 1, 2015 09:11 PM
kr1s
Aug 24, 2015 05:34 PM
FlowmasterMufflers
Jul 9, 2015 11:35 AM
