need electric fans info
Old Jun 22, 2007 | 06:45 PM
LPCWS6's Avatar
Default need electric fans info
Would the electric fan setup from a newer truck bolt right up in my 2000 yukon and what would be the best way to wire it up?
Old Jun 22, 2007 | 06:51 PM
chuckie311's Avatar
u have to make a custom bracket which isent hard.and there are a couple ways to wire it up but most have custom Wiring Harnesses made like i do.. do a search on efans or ls1 fans there is lots of info around on this..
Old Jun 22, 2007 | 06:53 PM
truckmann's Avatar
Not unless you have the 34" radiator and one easy way to wire it up would be to buy a harness from DLH2006 or Nelson and get your pcm activated to run the fans. The other wiring options are to run them on a manual switch or get a controller.
If you don't have a 34" radiator then it would be easier to get some ls1 fans out of an f-body and use them. They are usually cheaper too.
Old Jun 23, 2007 | 08:05 AM
LPCWS6's Avatar
Thanks I just moved to Phoenix from Detroit and down here that clutch fan is constantly running. It's killing my gas mileage and power. I need to do something, $100.00 a week on gas ain't working for me.
BTW is there anything else I can do to my truck to get better gas mileage and get a little power back at the same time in this heat? My truck is completely stock right now.
Old Jun 23, 2007 | 08:31 AM
Silver-Dollar's Avatar
If you do not want to buy used LS1 fans, then the 27" flex-a-lites are a direct replacement. Look for model numbers 292 and 298. The 292 is a stand alone model. The 298 reuires a controller, beit the pcm or separate controller.
Old Jun 23, 2007 | 10:22 AM
Derek @ EDO's Avatar
FormerVendor
I would go with the LS1 fans because of the price. They will Def. keep your engine cool and they are easy to install.
I had a set for sale with a harness but that sold VERY quickly. You can find the fans at a junk yard or on ebay. LS1 or LT1 fans will work great.
Old Jun 23, 2007 | 12:32 PM
LPCWS6's Avatar
I think I do if the 34" is how wide the actual fins are. The overall width is obviously bigger than 34". What do you go by?
Old Jun 23, 2007 | 01:09 PM
jknox's Avatar
Yup, just measure the core width without the tanks. If you've got 34" there then you're set to go with the bigger fans.
Old Jun 25, 2007 | 06:15 PM
chuckie311's Avatar
want more power get a custom tune your going to need one anyways to run the fans.im getting kick *** mileage ever since my tune money well spent IMO..
SS94S10
Jan 3, 2019 01:57 PM
drummer0415
11
Oct 24, 2015 08:16 PM
zraffz
Sep 20, 2015 08:25 PM
97gmc
22
Sep 8, 2015 10:56 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
