need advice on a smog legal cam
Old Jul 3, 2005 | 11:52 AM
1slow4.8's Avatar
Default need advice on a smog legal cam
I've been searching threads for a cam that will pass california emissions with no luck. Any ideas? By the way I have a 2001 4.8 with I/E.
Old Jul 3, 2005 | 04:12 PM
Good luck I have tried to get info on smog legal CA approved stuff on here but most of the guys on here are from Texas . I guess the smog laws are not as strict over there. $hit maybe I should move from Ca....
Old Jul 5, 2005 | 03:11 AM
Mr. Sandog's Avatar
No cam other than stock is 'legal' in the pure sense of the word (you won't find a CARB number on a cam). However, with tuning, cams up to 220 intake and exhaust duration pass pretty easily, and cams up to 224 have also been known to pass, but that's pushing it.
Old Jul 5, 2005 | 06:53 AM
Sport Side's Avatar
From what I understand, most camshafts are cut with -3 to -4 degrees of overlap @ .05 to pass smog. Of course, this doesn't hold true to every application.
To give you an example, a TR224 114 has -4* of overlap @ .05 and is said to pass smog.
Old Jul 5, 2005 | 07:01 AM
I've heard 224 is the line not to cross, but I believe the synergy motorsports 226 cams have passed smog.
Old Jul 5, 2005 | 06:30 PM
1slow4.8's Avatar
Than the crane 216/220 should pass with flying colors then, I hope.
Old Jul 5, 2005 | 06:40 PM
Mr. Sandog's Avatar
You shouldn't have any problems passing with that cam.
ARC
57
Feb 21, 2022 10:54 AM
sauldgold
Jul 23, 2015 02:15 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
