Name These Pieces???
Old Apr 17, 2006 | 11:49 PM
  #21
PappyDan's Avatar
Tribe Shaman
oh god Kevin I hope I am wrong with my answer.
it is a spiral lock that holds your wrist pin in on your piston.
Old Apr 18, 2006 | 12:19 AM
  #22
Yelo's Avatar
ooohhhh....I didn't think about that one !! That'd suck big time !!!
Old Apr 18, 2006 | 05:17 AM
  #23
02Reaper's Avatar
Originally Posted by Yellowsierra
I think its a inner valve spring if your running the dual patriots....
I agree, One of your dual springs is broken. Its way to big to be the spring on the inside of the oil pump.
Old Apr 18, 2006 | 07:53 AM
  #24
Flyer's Avatar
I'll check this evening, but I don't think the stockers have any locks, just pressed into the piston. I know the one piston I looked over real good didn't, butit was damaged, so I'll check another when I get home.
Old Apr 18, 2006 | 08:01 AM
  #25
TurboGibbs's Avatar
That is what I first thought when I saw it. Factory doesn't use the spiral locks I don't think. The one's i've seen is the round wire spring clips, you know in the shape of a C. Or do you have aftermarket pistons and spiral locks? The pic is fuzzy so it is hard to tell if it is a round wire clip or if it was worn to be tapered?
Old Apr 18, 2006 | 11:05 AM
  #26
LS1TRUCKGUY's Avatar
Im Guessin Spiral Lock.......at Least Thats What It Looks Like. If So, Thats Gonna Suck!
Old Apr 18, 2006 | 12:49 PM
  #27
Flyer's Avatar
It's not a lock .... My stock 5.3 has no locks. I just verified.
Old Apr 18, 2006 | 01:01 PM
  #28
Yelo's Avatar
I'm gonna have to stick with the bearing race then......
Old Apr 18, 2006 | 01:03 PM
  #29
Fogle07's Avatar
could it be the part of the retainer on top of a valve spring? maybe kind of sheered off. maybe not after i stared at your pieces more
Old Apr 18, 2006 | 02:38 PM
  #30
TurboGibbs's Avatar
oh yeah. The LQ9's are the only truck engines with floating wrist pins. in that case, probably the needle bearing retainer on the rocker as already mentioned. I can't think of anything else it could be.
